Old Feb 25, 2023 | 05:38 PM
pizzaguy
Default Re: Turn signal issues
I would replace ALL rear tail/stop and turn bulbs with the proper bulbs, as this has been discussed numerous times before and using the wrong lamps can cause WEIRD problems.
Do that and see where you are then.
Also, see my signature line, as it sounds like you used the forum search, which does not work, instructions are provided in how to use Google to more effectively search this forum.
