Old Mar 9, 2023 | 07:39 AM
dedwards0323
Default Re: Radio wiring color code assistance!
Originally Posted by sojo
I'm jumping in on this thread because it is so current and is wiring related.
Just bought my SRT and have purchased a new JVC HU from Crutchfield. I also bought their prewired adapter cable. I specifically told them I wanted to use the preamp outputs. The adapter cable is using the preamps for the speakers but not for the sub. I called tech support but he made no sense. Is this wiring right/ok or should I make an issue of it with Crutchfield....or modify the harness myself?? Or...would I even notice the difference??
Thanks for letting me jump into this thread.
If by saying you bought Crutchfield's prewired adapter harness like the one in the attached PDF, then that adapter harness is wired correctly.
If you bought everything from Crutchfield, then they should be willing to give you tech support on the install. They usually are pretty good in doing so.
