Old Mar 9, 2023 | 10:56 AM
  #41 (permalink)
sdultra's Avatar
sdultra
Default Re: VIDEO - Locked Out of Trunk? How To Override the Lock Mechanisms
Thanks for showing us the issue. First, it appears that you have the floppy handle issue when trying to open the trunk (boot), which is indicative of a pneumatic system failure, which is the pawl assembly that has ti be PUSHED into place in order to open the trunk. Until that is resolved I cant tell if the electronic lockout is engaged or not. Can you take some still images of the inside of the left hand side opening? I mean there must be some access just in order to accommodate the license plate fixture. The fact is these pneumatic lines travel along the trunk lip and if there was a full metal plate blocking this, I cant see how this would be engineered. Take the best photos you can with the best lighting possible. I like a challenge!!
