Old Mar 13, 2023 | 08:13 AM
dedwards0323
Default Re: Factory wheel size
Originally Posted by The Ikon
*I now this is 3yrs old…. BUT
As I was searching rim info about width and height.. I was a go 19” front and 20”rear I stumbled across many threads with various opinions and ideas.
And I run across members being negative with snide remarks or blatantly rude comments. This is a forum and some people just wanna be sure or aren’t as savvy on the search button and need one on one discussion tbs reading a thread without feedback….. let’s not discourage interaction… and not run off members. It’s not your forum it’s the creators and every member that’s active…
it’s a forum……🤫. The best comment is no comment at all sometimes.
There are Forum Members that run 19" front & 20" rear wheel/tire combos, so this is a viable option. Post #8 by amx1397 gives you the maximum height limits you need to abide by when upsizing your wheels. Then I would use the link I placed in Post #10 to compare the OEM setup to your revised setup to make sure you are within those limits. That link will also allow you to identify the optimum spacer you need to avoid any rubbing with the suspension. Good Luck with your wheel mods.
As far as the commentary provided by some Forum Members that comes across as intrusive or sarcastic, this is more reflective of a personality characteristic of a few individuals and I just ignore it as there's nothing I can do to change that behavior. I belong to several Forums of various car enthusiasts and sarcastic commentary exists on all of them.
