Old Mar 16, 2023 | 02:08 PM
Padgett's Avatar
Padgett
Default Pump and Security Module
'04 Coupe.
I wanted to check the connectors on the CLP/SSM in right rear.. Manual says to "remove foam". Except the foam is locked in place by the trim on side and back. Removed the pop inserts but does not budge, can only remove taillight access ports. How do I remove the trim to be able to remove the foam please ? YWTK
