Old Mar 16, 2023 | 03:55 PM
amx1397
Default re: UK Roadster Thread - drilling into the trunk
No, Jim. The pump is in the cavity in the trunk, below the trim. In a Roadster, this line goes up the wheel well and into the trunk lid at the passenger side hinge - there is no way to access it.
Also, if the electric lock is his issue , that won't help anyway. The electric lock slide a cam in place to stop the bottom from moving.
mark i had a trunk locked, I pulled the headliner down just enough to get to the lines. (per Rudy) the vac lines were right above the window under the headliner i cut the line and plugged into my a little compressor , vac opened and pressure closed the pump was under water jim
