Old Mar 17, 2023 | 02:51 PM
Ronman's Avatar
Ronman
Default Re: Pump and Security Module
Originally Posted by Padgett
Cannot see any, just nothing moves Guess I need to find another way to lock the hatch (fobs do not work or synchronise but keys start car just fine but cannot lock.)
The cluster has 4 screws that hold it in place. Have you removed those?
To access the pump in the trunk you have to remove back panel and the beige top panels. Then you can remove the foam and get to the pump.
Or you can just remove the rubber plugs from the bottom and see if water comes out. If no water leave the plugs out and forget about it.
