Old Mar 21, 2023 | 12:26 PM
Ronman's Avatar
Ronman
Default Re: How to lock coupe
Originally Posted by Padgett
I said in post #4 "Console switch does lock/unlock all" this includes the hatch. The console switch locks and unlocks both doors and the hatch, just as soon as I open the door, all unlock again. Can lock the doors with the buttons but is no button for the hatch.
have had two thoughts: either add a lock switch for the hatch or disconnect the door open signal. Second seems easier but would lose dome lights.
Anyone know if the BCM is always waiting for the "door open" or does it get a "turn on" signal when that or a fob button is pressed.
Just trying to help but your posts are not clear and redundant. You asked if the skreem was programmable? Wow
Then you keep creating a new thread for the same issue.
Your cluster is supposedly "glued" in. You don't even try dropping the bottom dash to see if the skreem is there by looking from the bottom.
I am done, what a waste of time.
