Old Mar 22, 2023 | 06:36 PM
onehundred80
Default Re: How to lock coupe
Originally Posted by Padgett
Reading through the service manual on page 8N-35 it talks about global vs selective central locking. Apparently in selective mode opening a door only unlocks that door and not all.
However the only way given is to press both buttons on the fob and my fob transmits but the car does not receive (fault B1000 N54/3).
Is there another way to toggle the Central Locking. ? With the Micropod maybe ? Does anyone know or am I SOL/
I think you have misunderstood the locking of doors under the selective method.
It is a bit confusing for sure.
From the Service Manual.
Global/Selective Central Locking
The keyless entry system has a Global or Selective mode function for central locking that can be programed by the
customer. The factory setting is Global, which will lock and unlock both doors, rear liftgate and fuel door centrally
when the respective button is pressed once. The Selective mode will only change which power locks unlock. To
activate the Selective mode, press both the Unlock and Lock buttons simultaneously for approximately five seconds
until the battery check lamp in the transmitter flashes twice. The Unlock button will then only unlock the driver door
and the fuel door when it is pressed once. Pressing the Unlock button a second time, unlocks the passenger’s door
and the rear liftgate. The factory setting can be restored by pressing both the Unlock and Lock buttons simultaneously
again for approximately five seconds until the battery check lamp in the transmitter flashes twice. If the
vehicle was locked using the power lock switch in the center console while in the Selective mode, opening a door
from inside unlocks that door only. If the vehicle was locked using the power lock switch in the center console while
in the Global mode, opening a door from the inside unlocks both doors and the rear liftgate. If the vehicle was
locked using the RKE transmitter, the doors and rear liftgate cannot be unlocked using the power lock switch in the
center console. If the vehicle was locked from the outside, opening a door from the inside will not unlock other
openings but it will trigger the alarm.
