Old Mar 24, 2023 | 08:28 AM
zip439's Avatar
zip439
Default Re: Central locking hell
Originally Posted by Marmite
Solved. I needed to push the lever on the inside at the base of the pawl. Credit to :magredvet his pdf helped make sense of the mechanism. Now on top opening that gas flap
I am of the opinion that every wing mount on the Crossfire will leak. It is simply the nature of the way it was sealed at the factory. YOU already have water problems. Not only be certain the gas filling area is sealed, but remove the wing from the car and re-seal the mounting plate to the car. I used "Mortite" rope type caulk as it remains pliable for a long time and allows the mounting plate to be removed in the future should the need arise.
