Old Apr 8, 2023 | 05:34 PM
pizzaguy
Default Re: Just bought a car roof not working 😕
Originally Posted by LARRYS
Hi all, just bought a 30k miles yellow convertible and roof not working, think it is out of sequence?
Anyone in the uk Midlands to help me please 🙏
Will pay for assistance and travel if necessary
Advice needed please and have already tried to follow the on line video but no luck so far.
Looking forward to bringing it to a meeting, hopefully with a working roof@
Thanks Larry
ALWAYS remember two things:
1) It's usually the divider switch
2) If it IS the divider switch, it's easy to prove that it indeed is: Put top down manually with engine running. Hit button, if top goes up, put it up all the way. If it won't go back down, then it's the divider switch.
The divider switch will stop the top from going DOWN but it won['t stop it from going UP. If it won't go UP or DOWN, then we have more investigation to do.
Also keep in mind that if you have issues with the door locks or BAS/ESP systems, you must fix those problems first, as those issues can inhibit top operation. If everything else in the car works well, only then do you troubleshoot the top.
