Old Apr 16, 2023 | 03:28 PM
zip439's Avatar
zip439
Default Re: Remote fob problems
Originally Posted by adoni
I have a similar problem, doors don't unlock with fob. Console works, auto-lock works AND if I put the fob in the ignition, turn one turn, fob is vertical, the doors lock and unlock. Panic doesn't work. Issue started when I let car sit without battery tender. Battery was dated 12/2015. Got new battery, then fob issue started. Tried all sorts of the re-programming techniques .. no luck.
When you push the FOB unlock button do you see a dim red light in the plastic window on the front of the FOB?? If no, you may need new batteries in the FOB or the contacts within the battery compartment of the FOB need adjustment. If you see the dim light flash then the likely answer to your problem is in this thread. Read post # 2 and #6. You should either disconnect or replace the siren under the windshield cowl.
