Old Apr 18, 2023 | 07:51 PM
pizzaguy
Default Re: I KNOW this has been asked a million times and someone will likely yell at me bu
FOr the last time, it is NOT your divider switch, if it was, the top would go up when you have it down all the way.
The reason for the odd beeps is that the top thinks it started a cycle, but did not finish that cycle.
How did you prove the pump has power? Unless you tore the trim from the trunk, there is no way to prove that. And if you tore that much trimp from the trunk, you should dig down on the passenger side, below the trunk, pull out the CLP/SSM and inspect it for water damage. Im starting to think the CLP/SSM has been wet. This is a very common reason for the top to refuse to work.
