Old Apr 19, 2023 | 06:12 PM
pizzaguy
Default Re: I KNOW this has been asked a million times and someone will likely yell at me bu
Originally Posted by wsmolich1
if the motor is destroyed, why would there have to be something wrong with the controller or other item you mentioned? It seems all other parts are working fine.
William
One more time: There is NO POWER on the motor unless the controller applies power to it. If it is sitting there with power applied to the motor, you have more than a bad motor.
Click the link below, download the manual, go to Chapter 8W, then to "Power Top". On page 8W-66-5 you will see that there is NO POWER to the motor unless you have the button pressed AND the cycle has started.
If there is power on the motor all the time, then something is WAY WRONG.
https://www.crossfireforum.org/forum...ollection.html
YOu want the "2005 Crosssfire NA and SRT6 (Coupe and Roadster) Service Manual.
That will make things clearer.
