Old Apr 20, 2023 | 05:52 PM
adoni's Avatar
adoni
Default Re: Remote fob problems
Originally Posted by zip439
When you push the FOB unlock button do you see a dim red light in the plastic window on the front of the FOB?? If no, you may need new batteries in the FOB or the contacts within the battery compartment of the FOB need adjustment. If you see the dim light flash then the likely answer to your problem is in this thread. Read post # 2 and #6. You should either disconnect or replace the siren under the windshield cowl.
Started with new batteries, after changing car battery, just to be sure. I will look into posts #2 & #6. It's still odd though, I turn the fob one turn, so it's vertical. Press lock, doors lock, press unlock, doors unlock. Turn fob off, exit car, fob only makes lights flash.
I will continue troubleshooting.
