Re: CHARCOAL CANISTER SHUTOFF VALVE OHM value
DO NOT go too small with the resistance. Current will flow based on the resistance, 28 ohms will be aboutt .5 amp. The modules are probably not expecting a lot of current and I would not go below 25 ohms, I still think 50 ohms is a safe value to start with. That should allow enough current for the ECU to believe the valve is working.
