Old Apr 26, 2023 | 01:18 PM
pizzaguy
Default Re: Battery Problems
Originally Posted by MCPO
pizza guy,
Still having problems with battery drain. When Diagnosis shows a code P2300 which states "Ignition coil 1 circuit low."
Could this have an affect on battery drain?
No. Fuse 11 powers the coils, it is on "run-start" power, not battery power. When you turn the key off, the "run-start" feed at pin 1 of the switch is depowered, which is what feeds fuse 11.
