Old May 20, 2023 | 04:13 PM
onehundred80
Default Re: Urgent need to fix
Originally Posted by OBSIDIAN-SIX
Just did an oil change two days ago before going to bed pumped out oil from dipstick removed filter replaced with new filter put back on took off oil cap filled oil from there put back on let car idle after 10 minutes or so sounded fine went to bed car meet last night going there sounded fine didn’t stop for gas or anything did get food at drive thru then parked for a few hours to hang out when going to leave tapped the gas just to break the tires for a second not much prefer not to then just accelerated off to about 40 started hearing something under acceleration like slapping or tapping sounds like metal parked at home now I’ve gotta address the issue went for coffee this morning started car it started and idled fine listened then I tapped gas to see if the noise was still there instantly sputtered and bogged down but no noise so I feathered the gas and it began to even out after few ugly sounding bogs/chugs so in park no sound tapped a little more no sound put it in neutral gas and no sound so I left when coming back I heard the random tapping under mid Throttle can replicate once driven and warm but not with a cold engine got home started car was a little under operating temp and no noise for a moment then it was being to come back but no bogging upon start
I cannot help but it is easier and quicker to refill with oil by pouring it down the filter hole before replacing the filter. Have you checked the oil level on the dipstick?
