Old May 29, 2023 | 01:50 PM
Goldwing's Avatar
Goldwing
Default Re: Replacement Hatch Glass
Rock Auto sells replacement struts. The ones on my SRT6 were not holding up that heavy wing and it cost <$30 to replace both. Pro tip: When re-installing the struts do not completely remove the little clips over the pivot ball(s). Use a small screw driver to pry them so they are loose but still over the ball, then slide the ball over the pivot pin and push the clip home. If you totally remove the clip, it is a pita to install with the pivot in position.
