Old Jun 2, 2023 | 01:22 AM
M60A3Driver
Default Re: !HELP! First Post, Braking problems
Originally Posted by kindaslowlol
For clarity, BRAKE, ABS, BAS-ESP are the new lights
Have you tried disconnecting the ground lead on the battery for a minute then reconnecting? I don't know if it will fix your problem. Just a suggestion.
Also you can check here and see if your problem is listed: https://www.crossfireforum.org/forum...s-repairs.html
You might also want to try posing in this in the lighting or interior section You might get more views there.
