Old Jun 2, 2023 | 10:34 PM
kindaslowlol's Avatar
kindaslowlol
Default Re: !HELP! First Post, Braking problems
Have you tried disconnecting the ground lead on the battery for a minute then reconnecting? I don't know if it will fix your problem. Just a suggestion.
Also you can check here and see if your problem is listed: https://www.crossfireforum.org/forum...s-repairs.html
You might also want to try posing in this in the lighting or interior section You might get more views there.
DId some diagnosing and spoke to a mechanic friend of a friend, said it was probably a bad alternator. the alternator is indeed not out putting the correct amount of power, which i read (dont know how true it is) that that could mess up the sensors
