Old Jun 3, 2023 | 10:54 PM
pizzaguy
Default Re: Having fuel issues.
You did not indicate that the fuel pump was not running, get into the RCM and verify if the fuel pump relay is engaging.
If it is, verify that you have 12 volts going to the pump, if not, determine why not. There is a pump fuse on the RCM make sure that is good AND that you have 12 volts on both sides of it.
There is a diagram of the RCM in the wiring chapter of the service manual.
