Old Jun 14, 2023 | 12:28 AM
  #131 (permalink)
nemiro's Avatar
nemiro
Default Re: M113K Into a Crossfire - Journal
13 June 2023
Busy day at work today, so not as much time to spend with the Crossfire. However, the rear subframe was removed from the car, so that part is done.
This is the first time this entire assembly has been out of the car. Overall, everything looks just fine. No rust, and the sway bar brackets look OK on initial inspection. They'll get a close examination before this goes back together.
Next will be the preliminary mockup of the modified subframe, and test fitting of it with the HAG215 in the car. Once everything fits, final welding and then assemble of the entire subframe can take place. Goal is to have it back in the car this weekend.
