Old Jun 20, 2023 | 01:07 PM
onehundred80
Default Re: 3D printed parts?
Originally Posted by AirdrieXFire
Has anyone built the files for any 3D printed parts for the XFire? I just had my foglight glass smashed and don't like the $300 USD prices I see. I have the other side in decent condition and could invert it for the side I need but if someone else has the file.... I'd expect thtat this forum would be a great place to share these. Not just foglights but all interior/exterior plastic parts...
Thoughts?
I'll certainly post mine when I make it. Assuming it comes out OK.
Kent
One owner - 2005 Limited in Grey with 36K miles
I do not think you will be able to make the glass clear enough to be of any use.
I think the part could be fabricated used Lexan, maybe two or more pieces shaped and fitted together.
Machined faces can be sanded down, then the surface is heated lightly with a propane torch. This melts the surface slightly and it comes out shiny and translucent.
I also think headlight lenses could be made the same way.
