I didn't realize that my strings were overlapping, I have not found any relatively good answers for the Noisy Fuel Pump. But since my Post, I have absolutely verified the humming noise on my vehicle which I believe others have heard, was the External Fuel pump. Easy access and easy swap out..
Simply remove the fuel pump Fuse, crank the engine to relieve the fuel pressure, remove the plastic pan under the car, clamp the Hoses, detach the electrics, remove the hoses, unclamp and replace the canister, and reverse the order.
Just wanted others to know.
