Old Jul 20, 2023 | 08:20 AM
  #54 (permalink)
zip439's Avatar
zip439
Default Re: AirBag Sensor Module - Airbag Failure Light
Originally Posted by ignite
The same situation came to me. As i live in Russia, there`s completly no way to get new ORC or any other variants. SO! i have an idea - byu orc,immo and engine computer from 03-06 m/y crossfire and repin connector for it. I think it will solve this problem comletely!
NO, that will NOT work! The "engine computer" PCM is linked to a specific car by it's coding in the ignition/start authorization sequence. PCM is not inter-changeable.
If getting a correct ORC is impossible for you, the easiest solution is to drive without the airbags operating and simple pull fuse #3 in the underhood fuse box will keep the warning light off.
