AirBag Sensor Module - Airbag Failure Light
Old Mar 24, 2025 | 07:58 PM
  #61 (permalink)
Teuffelhunden's Avatar
Default Re: AirBag Sensor Module - Airbag Failure Light
Disconnect the battery and unbolt the seat. Under the seat is a yellow connection- All yellow connectors correspond with airbags. Disconnect it, spray in some contact cleaner, blow it dry, and reconnect it. This fixes the problem not just on Crossfires but most cars 90% of the time. What happens is the seats are so low, the connector(s) drag. The connections of the SRS are monitored closer than an average connection and rightfully so. If any one connector becomes just slightly loose, it will throw a code. For the "Squibs"- airbags in the sides and bottom cushion of the seats, these typically throw a code when it thinks someone is in the seat but does not receive input of a person's weight. For these, you can simply punch up and down the side of the seat and across the cushion, this typically resets those.
Old Mar 26, 2025 | 02:53 PM
  #62 (permalink)
Learned something new today!
Old Mar 27, 2025 | 06:32 PM
  #63 (permalink)
That's just one way that may fix the problem; start with the simple things first!
Happy to help.
ED.
lightninle
Feb 6, 2019 08:28 PM
lightninle
Feb 4, 2019 02:59 PM
electroryan
Jul 17, 2017 06:51 AM
shaverj
49
Jan 17, 2012 05:09 PM
jrigsby
Nov 12, 2006 06:38 AM
