Old Jul 20, 2023 | 02:26 PM
  #55 (permalink)
ignite's Avatar
ignite
Default Re: AirBag Sensor Module - Airbag Failure Light
Originally Posted by zip439
NO, that will NOT work! The "engine computer" PCM is linked to a specific car by it's coding in the ignition/start authorization sequence. PCM is not inter-changeable.
If getting a correct ORC is impossible for you, the easiest solution is to drive without the airbags operating and simple pull fuse #3 in the underhood fuse box will keep the warning light off.
Pcm linked to immo module/at module. If I get all this modules from other car - why they won't work together?
