Old Jul 25, 2023 | 02:46 PM
pizzaguy
Default Re: Oil Fouled sparkplug
Originally Posted by Crow13
Dear Pizza... valve stem seal sounds so much better, and yes, a compression test would show something, but would it differentiate between a bad ring and a valve stem seal.
Thanks !
Yes. Bad rings cause low compression, as the cylinder leaks past the ring. Valve seals are not consequential to compression, as the valve is closed during compression anyway.
