Old Jul 30, 2023 | 06:18 PM
waldig's Avatar
waldig
Talking Changed key fob car cranks and stalls !!
I did it to my self.........changed the key case and the dreaded skeem fault hit me. THe car cranked 3 times and quit - reset the battery and it does it again. IF YOU CHANGE THE KEY FOB THERE IS A SMALL BLACK HUNK STUCK IN THE CASE. IT MUST BE CHANGED OVER TO BE ABLE TO START THE CAR!!!.
The identity of the key is this black piece, not attached to the printed circuit board, stuck to the plastic case. I thought that I had killed the car, so dont be a Woody, switch the personality block over to the new case.
I WAS SAVED AGAIN BY ROB AT NEEDSWINGS, THANKS FOR THE INFO ROB - YOUR THE MAN.
