Old Aug 6, 2023 | 03:05 PM
pizzaguy
Default Re: ESP/BAS Light // Stalling on streets
Originally Posted by RReyes
Hello everyone,
I´ve been struggling a little with my car almost everyday from a few weeks to date. It tends to stall on the streets and the ´´ESP/BAS´´ comes up when stalls, when I press the speed pedal iut won{t respond, what I have to do is turn the car off and start up again to keep running but that does not assure me that it wont happen in the next miles to go. I´ve been registering some inputs from a couple of days trying to determine a pattern but can figure it out yet. Hope any of you could give me some feedback about this issue.
If the engine stalls, the pedal won't respond because the engine is not running. Does the pedal refuse to respond when the engine is RUNNING or just when the engine stalls? Based on your post, I think the pedal only fails when the engine stalls, that makes me think that you have an engine stalling problem that is caused by a bad Crank Position sensor, bad fuel pump, electrical disturbance that is confusing the ECU, etc.
If the engine stalls, WHAT LIGHTS come on? ONLY the BAS/ESP light or other lights as well? In my experience, a stalled engine lights the dash up with a lot of lights. The BAS/ESP light is MEANINGLESS in this case.
I believe you are using an ENglish to Spanish translation device, if so, it may be hard to communicate effectively. If needed, I think I can get the help of a Spanish speaker to help us.
