Old Aug 8, 2023 | 03:03 PM
pizzaguy
Default Re: cross fire 2005 falla
Originally Posted by davidperez12
tengo un crossfire 2005 no lo quiero vender en partes y ya programe dos llaves me dicen que el skreem funciona y tiene 4 llaves activas
Trata de encender 1 segundo y se apaga , despues de 3 intentos tengo que desconectar la bateria.
por cierto filtro de gasolina alguien sabe como se conecta ? creo que lo hicieron mal
nota si inyecto gasolina por el multiple de admision (aire) puedo mantenerlo encendido 30 segundos
lleva estacionado 3 aņos.
no lo quiero vender en partes es un gran coche.
I have a 2005 crossfire I don't want to sell it in parts and I already programmed two keys they tell me that the skreem works and has 4 active keys
It tries to turn on for 1 second and it turns off, after 3 attempts I have to disconnect the battery.
By the way, does anyone know how to connect the gasoline filter? I think they did it wrong
Note if I inject gasoline through the intake manifold (air) I can keep it on for 30 seconds
It has been parked for 3 years.
I don't want to sell it for parts, it's a great car.
The fact that you must disconnect the battery to get three more bad cranks, tells me the SKREEM is the issue.
But if you can get it to run for 30 seconds with gasoline, I think M60 has it right: You have a fuel delivery issue. Measuring the fuel pressure at the rail with a fuel pressure test gauge is what I would do. THey are inexpensive test kits. You want about 60 PSI pressure. The pressure will be there when you turn key on, but if engine does not start, the pump will stop and pressure will fall quickly, this is normal.
For SKREEM problems, Josh Chase at https://themercedesswapshop.com/ would be who I would go to for repair. He is in California. He does not speak spanish but you can use google translate.
But again, if the engine tries to run with gasoline in the intake, I think the SKREEM is fine and you have fuel problems.
