Old Aug 8, 2023 | 04:21 PM
  #110 (permalink)
pizzaguy
Default Re: Convertible Top Sensors
Originally Posted by MCPO
Pizzaguy,
Great news. My top is functioning perfectly. The problem was, the mechanic at the Chevy dealership where I purchased the car, replace the left main lift cylinder and
when he installed it he reversed the wires going to the travel sensors. Klaus recommended that I check these wires and sure enough they were installed backwards.
I want to thank you also for all the advice you have provided for this and many other problems I have experienced.
MCPO
Another owner (Jeff in Greer, SC) had a similar experience. His problem was that the bottom sensor was not seated all the way (can't imagine how that could be). He "worked it in", cycled the top manually, then hit the button and it was fine.
He'd sent the cylinders in to Klaus as well.
