Old Aug 13, 2023 | 09:04 PM
pizzaguy
Default Re: No crank after new keys
I do too. But it IS a common fail item. I'd suspect the coil on the engine control relay has gone open, because you physically closed it and the ECU powered up. The ECU is powered by that relay. Power for the coil comes right from the ignition switch.
