Re: Locking System won't disarm with FOB
Thanks for your response. I have already removed the "brain" from that tub in the back, repaired connectors that rotted off, drilled a drain hole in the bottom and reassembled everything. It "should" be dry, but I've been needing to get back to the 'brain' because I lost my interior lights and the headlamp delay functions a year ago... SOMETHING is going on with the brain in the trunk. I have a complete 2nd brain if I need to replace this one. What is the "module" you're writing of? How can I "ID" it so I can test it? Where might I look on this unit to see what may be causing my other problems? Thanks!!!
