Re: Won't Start problem
Continuing saga of the poor old '05 Xfire. The classic 3 times and no start is back again. It would "usually" start, after sitting for a while, so I let it sit overnight. Now a new "no start" symptom. Tried to start and dash lights came on but no crank! I tried about ten consecutive times and then it started right up. Has new battery and will check all my grounds. Tried couple times and again it started right up again. I know I have "threatened" to send SKREEM to MSS but hasn't happened yet. Been too darn hot to get out there and remove the dash. (113 degrees with heat index) Also I know that some of the dash parts will break because it' old and brittle. I did buy a Plastic Weld Kit to repair anything that breaks.
