Thread: Top Won't Latch
Old Aug 28, 2023 | 08:45 AM
gump's Avatar
gump
Default Re: Top Won't Latch
THis comes up from time to time. It is hard to say what it is, because there are a few similar issues that all kinda sound alike.
But I suspect the top is not lined up exactly right such that the hooks are not 'fitting into' the opening in the windshield frame and therefore, the D ring can't go back where is should be cause the hooks cant seat where they should seat.
Take a look at that. As the top is pulled down, are the hooks not lining up with the opening?
Can you use your phone to shoot a short video of what is happening? That way, we can see exactly what is going on and take it from there. There are adjustments in the linkages/straps that can cause this, it's not all that hard to fix, most of the time.
I was able to get a better look at it on the weekend. It looks like the hooks are going into the opening but are stopped on something and so don't hook in to pull all the way down. Where are the linkages/straps to adjust in order fix the alignment?
