Old Aug 29, 2023 | 07:22 PM
pizzaguy
Default Re: Key stuck in ignition
This came up on Fakebook a while back. That "throttle cable" thingy that goes from the shift to the ignition switch is the culprit.
Bob McCubbin suggested that you could disconnect the cable at the ignition switch and the default position of the 'slider' in there is "unlock", if you dont want to chase this.
