Old Sep 1, 2023 | 12:53 PM
pizzaguy
Default Re: Any info or cowl leaks?
Originally Posted by mariontr
I seem to see different part numbers for the transmission control module on ebay:
A0335451132, A0335451232 and A0335451332 (this seems to be the latest per Chrysler (68030996AB) that fits 2004-2008 Chrysler Crossfire - 68030996ab) would any of these work?
Forget part numbers and forget eBay. You want the TCU from the same year range and model variant as your car:
2004-2006 or 2007-2008
Limited or SRT
Get one from a 'parts car' not off eBay.
ALSO: If the module is damaged, the harness is corroded as well. I would get in there and determine if there is water damage or not. If you were lucky, the water never got to the TCU or it's connector. If it did, you need the last few feet of the wiring harness as well, you CAN NOT clean the corrosion from inside the connector pins.
If yours is damaged, we can find a parts car. Zach in SC and Cliff/Eric in Ohio both have parts and access to parts cars.
