zip439
"Replaced the gaskets on the electrical connector" ??
Are you talking about the two o-rings? Did you use a new plastic plug or the old plastic plug with new o-rings. The new plugs from Mercedes will not work on our cars. You must use the original plug with new o-rings. If it wasn't leaking you should have left it alone.
Sorry I should have said O-Rings instead of gaskets. I used the old connector. And it was leaking hence I really wanted those replaced. So far no drips under the car.
