xintersecty
Edited the original post for clarity. Does anybody know if transmission codes show up on ODBII can bus? Does anybody have any good substitutes for a DRBIII scan tool? I have not gone back under the car. I was just so discouraged.
This has not been answered! I am still not showing any codes.
OK I got the car jacked up at lunch today just to do a basic diagnosis. There is a bit of fluid leaking around the electrical connector. I will need to remove the heat shield to pull it and check the connector. I did start the car and put it in gear. Looking at the drivers wheel I can see it rotate when I give it gas. What's funny it rotates forward both in reverse and drive. Still looking for suggestions. I can replace the conductor plate that's about the only thing I can do.
