xintersecty
This has not been answered! I am still not showing any codes.
OK I got the car jacked up at lunch today just to do a basic diagnosis. There is a bit of fluid leaking around the electrical connector. I will need to remove the heat shield to pull it and check the connector. I did start the car and put it in gear. Looking at the drivers wheel I can see it rotate when I give it gas. What's funny it rotates forward both in reverse and drive. Still looking for suggestions. I can replace the conductor plate that's about the only thing I can do.
I believe some of your issue(s) is/are you might have transmission fluid wicked up into the TCM under the console, also, the wheel rotating when in drive/reverse in the same direction, I believe is normal. Fix the leak and check the wiring up to the TCM for wicking of the transmission oil. Good luck!
