xintersecty
I finally removed the valve body to see about rebuild or replacement. For some reason the selection lever broke and caused my transmission to no longer shift into gear.
The missing chip is on the right hand side
GOOD catch, that is quite a failure mode there. I hope you find that part, it'll get real expensive if you can't... Good luck!
