nemiro
The closest I have found so far are newer MB hubs. They are the right spline (27, IIRC). However, they use 14mm wheel bolts, which I have not tried with the CF wheels. However, if those were to work, then the whole axle problem starts to get pretty simple, pretty fast. I just have yet to order some.
Just received my answer back from Gforce on if they could adapt there mustang 550 axles crossfire and here is the answer
Yikes... 25 spline is incredibly small, and I'm guessing you wouldn't have enough room in the hub to go to a 32 or 33 spline. On top of that, it's not just the spline count that you have to deal with; It's how the outer stub flange interfaces with the wheel hub and knuckle assembly, as well as any ABS requirements... I'm afraid we're not currently in a position to help out with something like that
