Isaacmaple08
Turns out both low beams burned out at the same time. Both were bad. Never seen that happen before. I would assume a surge or ground issue, but if that were the case the fuse should have popped too, right?
Not sure what to make of that. I do see the dome light sometimes flickers at idle, they aren't LEDs, maybe an issue with the voltage regulator? unsure if thats even related. The previous owner definitely cut some corners on wiring that I've been fixing this week.
You might want to do James1549's ground fix as a precaution. Also, in that same thread, CROSSFIRERUSH (post #18) replaced the smaller ground wire located under the car. Both are very easy and fast fixes. The cables are available on amazon.
Here's a link to the post:
James's ground wire fix
