Old Oct 24, 2023 | 09:11 AM
svtmerc's Avatar
svtmerc
Default Re: Help diagnose intermittent rough running
I had a little nugget of stumbling this morning on the drive in to work.
In my endless pondering, a question popped in my mind... I have some oil leakage due to the oil level sensor not sealing completely. Is it possible that negative crankcase pressure is pulling in unmetered outside air and pulled in the intake via the pcv system causing the lean codes and intermittent rough running?
