Shmuller
Hi. I have a 2005 coup with spoiler stuck in up position. The trick of opening and closing the hatch before using the override switch used to work, but no longer does. Battery may be old. I read on line about a microswitch replacement, but it was for later year models. Also any information on the small tool and how to manually retract it might be helpful. Thanks!
i found that my problem was the cooling fan inside the ecu box shot. Causing the the back fuse to keep blowing taking out a wide range of functions for the car. I removed the ecu fan and replace the fuse and it works perfect.
