Help! Spoiler deployed, won't retract
Old Nov 21, 2022 | 11:58 PM
Matticmass's Avatar
Default Re: Help! Spoiler deployed, won't retract
Originally Posted by FinUp
I had a reply to my original post to tell me to clean the fin. Even though it looked very clean, I did clean it thoroughly and it worked fine again. I sold my Crossfire a year ago, but enjoyed it when I had it. It always turned heads and started conversations. Hope this helps.
the car was white green and black when I got. I washed it throughly so now it white again. When I had the spoiler assembly removed from the vehicle I lean out the drains, which were heavily clogged.- I’m leaning towards the down limit switch as the culprit. However I haven’t had time to run the proper diagnostics
Old Nov 28, 2022 | 08:37 AM
richb55's Avatar
I have a good functioning alabaster white wing for sale if any one of you that own a coupe and are experiencing problems Anybody interested ??
Old Oct 26, 2023 | 11:18 AM
Shmuller's Avatar
Hi. I have a 2005 coup with spoiler stuck in up position. The trick of opening and closing the hatch before using the override switch used to work, but no longer does. Battery may be old. I read on line about a microswitch replacement, but it was for later year models. Also any information on the small tool and how to manually retract it might be helpful. Thanks!
Old Oct 26, 2023 | 12:52 PM
bluecoupe's Avatar
I think you may have solved your problem when you said the battery may be old.
Old Oct 26, 2023 | 02:45 PM
The spoiler is an early warning system for a weak / failing battery.
Old Oct 26, 2023 | 03:13 PM
Ditto on last two replies, quite possibly an old battery...
Old Oct 26, 2023 | 03:33 PM
Matticmass's Avatar
i found that my problem was the cooling fan inside the ecu box shot. Causing the the back fuse to keep blowing taking out a wide range of functions for the car. I removed the ecu fan and replace the fuse and it works perfect.
Old Oct 26, 2023 | 04:12 PM
Ronman's Avatar
How did you end up checking that specific fan?
Old Oct 26, 2023 | 04:36 PM
That's a new one.
Old Oct 26, 2023 | 05:37 PM
Shmuller's Avatar
Thanks all. My battery was actually less than a year old, but it did discharge over the summer in storage. However, I threw it on the jump box and was able to cycle the spoiler right down.
Old Oct 27, 2023 | 07:53 AM
Curious, did you replace that fan in the bottom of the box? That fan keeps all those electronics cooler in that box, with air from the cabin.
Lockhouse
Mar 20, 2024 04:50 PM
RED DOG
44
Oct 27, 2020 09:00 PM
Reliableron
Oct 17, 2015 10:19 PM
atdavis2
Sep 21, 2015 01:25 PM
davidc90
Sep 6, 2015 10:37 PM
