Old Oct 31, 2023 | 11:15 AM
onehundred80
Default Re: Brake Light & Air Locking System Issue
Originally Posted by mikemadeit94
Switched the yellow tubes around and I think everything is working as it should! When im in the car with it running I press the lock button, my gf went around the car and everything locked except the gas tank im assuming that's how this is supposed to function? With the car off and using the fob everything locks and unlocks I would just like to thank everyone on the forum for the guidance and another repair! The middle nipple is for the driver side door the nipple closest to that is passenger the the remaining nipple furthest away is trunk and gas tank!
The gas cap only locks when the fob is used to lock the car from the outside. It stays unlocked when you are diving.The pump outlets are for the drivers door, passenger door and hatch/trunk and gas tank cover. The hatch and passenger door can be programmed to open when the drivers door is opened from the outside. When the roadster console is locked I cannot say, probably when the car is locked from the outside.
