Old Nov 1, 2023 | 08:01 PM
pizzaguy
Default Re: replaced ignition switch but key still sticks in start & cranks no start
I've been a member here for 14 years, I've owned three Roadsters, NEVER heard of a key "sticking" in the start position.
Generally, a bad crank sensor will work fine with a cold engine, but not when engine is hot - so I'm doubting the CPS is the issue.
I'd verify that fuse 11 is ok (fuses the plugs/coils) and then I'd measure fuel pressure at the rail and if you have 58psi +/- 3, I'd check to see if the plugs are really firing and go from there.
